meggala wrote:the rb 26 crank and rod fit in the rb 25 with out a problem and then you can bore it out a little to 87mm and yeah you will be pretty close to 2.7 but you will also have the strength and revability of the rb26 bottom end. its a very good move. meggala
Hey Meggala I have question for you. Could just the Rb26 Connecting rod be used with out the rb26 crank shaft? A related question: is there a different between the Rb25 rods and the Rb26 rods since the engines have the same stroke?
I am looking for a solution to what I heard as being the weakest point of the RB25 when pushing high hp and higher revs ... the connecting rods!?!? So what steps one could take to help the engine along before having to do a full engine rebuild (blanced crank, aftermarket rods & pistons, etc.)
Thanks
Wail
