2 quick questions
Q_SHIP
Car: 1999 Q45T with a billion miles.
1. what is this whining coming from my backseat? I know it's the fuel pump but why is it so loud? Should it be that way?
2. I know there has been a subject on this but what do you use for rear end lube? What do I need to get the job done? Do I need to suck the oldstuff out or is there a way to let it drain? Thanks
qship96
Car: 1996 Infiniti Q45
replace fuel pump ASAP before it takes out the more expensive controller.search the board,many posts on this topic.
rearend had drain&fill plugs.use a synthetic gl-5 gear oil-I am using Redline 75w-90 at 8.00 per quart,you need 1.5 quarts to refill-mobil 1 and amsoil also make excellent full synthetic lubes-I do this every 12 months,along with every other fluid.
Q_SHIP
What makes the pump go bad? Is there a way to just repair the pump before it gets bad?
qship96
pump goes bad due to age{usu},dirt in gas,rust and debris in tank,etc-pump is non-servicable and must be replaced before it damages controller by overheating due to increased current draw by pump.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I will disect my old fuel pump and see if maybe we can see what wears...
SeVa-S13
Car: '05 GTO 6spd
Q_SHIP wrote:2. I know there has been a subject on this but what do you use for rear end lube? What do I need to get the job done? Do I need to suck the oldstuff out or is there a way to let it drain? Thanks
I'm so very sorry but that's one of the funniest thing I've ever read on this board. I have nothing technical to add, sorry again.
Q_SHIP
Oh man, I better go back and edit. That sounds bad. Nice to know where your mind is.
