2 Quick Questions Regarding Fuel Pump
FiKtIOn
Fuel Pumps -
Walbro 255 for KA/SR will fit with CA, correct?
Secondly, is an FPR needed, or is the pump just bolt and go?
rico05
Car: 1992 RMS13 w/ CA18DET
Bolt and go. I have a SR/KA Walbro 255lph.
FiKtIOn
Thanks
Bizz
Do you think a 190lph would be enough for a low boost application?
Trigger
low boost probably
rico05
To be honest, I have a buddy that has been running 15psi on his SR w/ stock fuel pump. Mind you I in no way reccomend this at all. Ever. Under no circumstances. But it can be done. Just don't.
biosehnsucht
The walbro's are all within 10-15$ or so of each other, might as well go for a 255 high pressure :D
I got mine from auto performance engineering in Garland since it was a local pickup and pretty good price :D http://www.apeusa.com
Nismo1182
Car: Z06
Fuel pumps arent motor specific.
FiKtIOn
Normal or High-Pressure more beneficial?
Nismo_Freak
Car: 89 Nissan 240SX
FiKtIOn wrote:Normal or High-Pressure more beneficial?
High pressure.
Normal is for an n/a system running lower pressures.
XtremeHKS
You would have to be insane to "save" $100 on skippin out and using your 15 year old fuel pump.
Bizz
So the stock fuel pressure regulator has no problem with the HP 255 unit?
Also anybody have a better/cheaper link than http://www.apeusa.com? Not that their prices are high or anything....just being a cheap b!atch.
float_6969
support our sponsors!!! Try http://www.enjukuracing.com or http://www.srswap.com I got mine from Heavy Throttle (srswap.com)
