steed77 »
https://forums.nicoclub.com/steed77-u138200.html
Fri Sep 25, 2009 7:40 am
Here is some of the stuff I can list off the top of my head.... Missing a crap load more
Sonic Blue clear coatCarriage Works billet grills upper and lowerBillet fuel doorWindow tint 20% sides 5% rearVent shades vent guardsRUSLOW (Stan's)1100 lbs front springs 2inch dropRUSLOW (Stan's) Pan hard barRUSLOW (stan's) Dimpled and Slotted Front and Rear RotorsHawk Brake padsJLP 4inch drop shacklesFord soft tonu coverBillet antenaBed rugGround kitSilverstar headlight and fog lightsSeveral billet undrehood caps and covers
PerformanceJDM cold air kit K&N filterREM composite intake tubeAcufab single blade throttle bodyExtrude Hone intake Polished ribsJDM Phenolic Spacer2.90" Ultra-Grip Blower Pulley Reichard Racing.METCO Ford Lightning Auxiliary Blower Idler100MMMETCO Billet Idler Pulleys 90MM (2X)METCO clunk washersMETCO Driveshaft LoopFord Camber Bolt kit (4X)Cobra water pumpNAPA 68in beltJLP 6lb lower pulleySCT chip 12:1AF CUSTOM DYNO TUNEDJDM Electric Fan kitFactor Tech Valve BodyMAC deep aluminum transmission panJDM/KOOKS Stainless Steel Long Tube HeadersJDM Stainless Steel Mid pipesMagnaflow Stainless Steel High-Flow catlic converters (2X)Magnaflow Stainless Steel Cat-back exhaust systemJLP 58in Traction BarsNGK TR6 plugsQA1 shocksHuge F&R sway bars with customized end-links
AudioAlpine flip-out XM deckPolk audio speakersAudiobond pro 10in sub1200W mono block amp1F cap4AWG wireMonster interconnectsCustom box and amp rack
