idamaster wrote:1.. What should my VAC be at idle on the boost gauge in BAR ?
2.. Can the turbo stop spooling right after i turn off the motor, or should it spool for a little longer. Sounds kind of like when you turn off a saw. Could this be some shaft play?
Blacktop sr20
you shoudl read negative boost at idle like -20mmHg
BB turbos make this sound or spinning sound when you turn the car off-- what kinda turbo do you have... granted it should not sound like a saw but it will spin for like a minute or two.
