2 QUESTIONS
Forum for the unique Murano, and official home of Nissan Murano Club!
MarciasMurlotMurano
Car: 2005 Nissan Murano S AWD
Hello. I'm new to this forum so I hope I'm doing this correctly. I am the proud owner of a "new" 2005 Murano. I have 2 questions. I was told the air cabin filter needed replacement. I asked how much and he told me the filter was $50! I told him to leave it as I would do some research to find a cheaper one. Lo and behold, I found one that was $12 at the autoparts store. Anyway, I'm having trouble figuring out how to open the white filter cover inside the glove box. It says to "push" to tabs but this does nothing. Anyone ever change this filter and if so, can you give me some tips?
2nd question is, do they sell a cargo net for a 2005 Murano? When shopping and putting things in the back, stuff moves around when driving. I've done many searches but nothing seems to come up, which, may be an indication that in fact, they don't have cargo nets available. Anyway, any info with this issue would be helpful as well.
Oh, and I decided to change all my wiper blades (front, no problem) but found the rear blade is more of a challenge. Do you have to take off the entire arm to replace the blade? Seems so. From researching this issue I've found answers to "if you take it to a dealer it's going to cost an arm & leg" to "just cut it off and RainX the back window." I like the wiper there though so I guess I'll try taking off the entire arm to change it. Hopefully no special tools are needed in order to do so.
That's it for now! Thanks for any help you are willing to share!
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Hey there! Welcome to NICOclub, glad to have you as a member of the Murano Forum!
- My best answer for you on the In-Cabin filter is to check the Nissan Murano service manual. This is very detailed. Here is a link to the service manual.
http://www.nicoclub.com/FSM/
- As far as the cargo net goes, I know they do exist, I had one for my previous '03 Murano. I saw one a used one (which looked new to me) for $15.
Good luck and enjoy the new ride! Merlot is a sweet color!
MarciasMerlotMurano
Thanks for your response Timmbo. I did look in the service manual for that air cabin filter but did not see anything at all about it.
Also, where did you see the new (used) cargo net for $15? I'm not even sure if there is a place to hook a net on anyway. Anyone else with a 2005 Murano have a cargo net installed?
Thanks!
Timmbo
There is now a few of them on eBay. One used and a few new. There was a new one at just under $20!
JST2KWIK
Car: '92 Nissan 240sx Vert
we had a cargo net for our 04 Murano but for some reason our 06 did not come with one. (?) Anyway I went to the Nissan dealer's accessory store and did not see it in their catalog, but if they have them for the rogue or quest or something you should be able to use that. And there are little pins on either side that it hooks to.
nafddur
Car: ???? Nissan Maxima
???? Nissan Murano
MarciasMurlotMurano wrote:Hello. I'm new to this forum so I hope I'm doing this correctly. I am the proud owner of a "new" 2005 Murano. I have 2 questions. I was told the air cabin filter needed replacement. I asked how much and he told me the filter was $50! I told him to leave it as I would do some research to find a cheaper one. Lo and behold, I found one that was $12 at the autoparts store. Anyway, I'm having trouble figuring out how to open the white filter cover inside the glove box. It says to "push" to tabs but this does nothing. Anyone ever change this filter and if so, can you give me some tips?
Since this thread is 3 months old and I just saw it (just joined the site), I don't know if you resloved your in cabin filter or rear wiper blade replacement issues.
If not, the procedures to do both are really simple - ie take only a few minutes each and require almost no tools (none for the filter and only a 10 mm wrench or socket for the rear blade). If you still need help, ask and I can explain both further.
Return to “Murano Forum”
