evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Nov 11, 2006 8:06 pm
first of all, I moved this to the classis ssection
as for the 5 speed, there were few available in the s30 chassis (70-78) only the 77-78 had the option of a factory 5 speed and it was a weak one at that, they simply added 5th gear to the 4 speed and the countershaft couldn't take the abuse so it borke, the dealer used to offer a kit to swap in the 5 speed from the roadsters, the most easy available is the S130 (79-83) 280ZX n/a 5 speed, the turbo 82-83 models were stronger but hard to find, either will bolt in but as I recall the shaft will have to be modified to fir the r180 diff in the earlier cars,, the n/a 5 speed will bolt right in and use the stock driveshaft, priced used range from $100-350
as for the gas tank, the best bet it to take it to a radiator shop have it cleaned and sealed, as far as I knwo there is no aftermarket units available, and 70-76 will go in with some re-arranging of hoses, the ideal units would be the 70-74, but even if you fina a used tank it shouls be cleaned and sealed prior to install, they tend to cost around $100 used of course your results may vary
is he planning on keeping the 2.4? still using the stock crappy su copy carbs? what are his plans for the car?
