surfwax95 »
https://forums.nicoclub.com/surfwax95-u19092.html
Thu Jan 13, 2005 4:02 pm
1995 Nissan 240sx standard trim. 118,000 miles. 5 speed.
Struts: squeaking noise coming from rear on bumps. the boot around the strut is ripped a little. Do I need new struts?, and if so, where could I get some aftermarket for cheap?
Engine: When it's cold (not the engine, the air temp.) the engine makes a noise similar to the shaking of a spraypaint can. goes away after 1200rpm. gas mileage is still about 25-28 but the noise is driving me crazy. The check engine light came on 2 days ago. Is there a way to run diagnostics without taking it to a mechanic?
thanks guys (and gals)
