Veen »
https://forums.nicoclub.com/veen-u28006.html
Thu Nov 24, 2005 5:30 pm
For the 02, I just extended the original plug on the CA MAF (the only one that I noticed that was the same shape, with the same snap, and the same three plug configuration) and ran it over. If I read the wiring guide correctly, it's over on the USDM passenger side (assuming you put the ECU over there) on the same sort of branch type thing as the MAF plug.
Now you've got me all nervous hoping I didn't misplug it.
Edit: Well, just went to the garage. I have like two dozen spare electrical plugs here, which still really makes me leery. However, everything in that install FAQ is properly hooked up where it should be, and as far as I can tell, the plug coming off of the O2 sensor only mates up with one plug on the entire harness here. Still though, this whole "extra plugs" thing is ridiculous. What did all of this crap go to? Surely there's not supposed to just be a crapton of plugs all floating around with nowhere to go, right?
