2 questions..need to no asap
christopher12
Car: 1996 240sx
where is the knock sensor located? and can i go full stand alone ecu to turbo my obd11 and maybe pass inspection? greddy emanage blue or aem ems
itwillboost
Car: 2000 alti
2002 Frontier
1995 accord
Obd 1 or obd II ? That makes a difference, but you can make either work but it changes your options. Also aem and greddy emanage are 2 completely different things.
christopher12
Car: 1996 240sx
yes i no there 2 diff things. thats why i said aem (or) greddy emanage
WDRacing
Knock sensor is under the intake manifold between the #2 and #3 cylinder. Have you considered just running a FMU?
christopher12
Car: 1996 240sx
well my turbo is good for 400hp or a lil more so thats my target..i alway thaught fmu wasnt really safe and its only good for low boost
ghostboy
Car: 1995 240sx
sorry to thread jack but ill soon be building my my ka in my s14. Im only going for a low boost basic setup, i was told an FMU was the way to go but which ratio remains a mystery. people were hovering around 6:1 and 8:1 but still no clear answer lol. details are:
nissan t25
wanna run 7 psi
walbro 255
3 inch exhaust
stock internals
any ideas? flame if needed.
PapaSmurf2k3
Site Admin
7psi is pretty much the max I would go with an FMU. If it were me, I'd run the 8:1 with 93 octane, and replace your factory fuel pressure regulator with something that can regulate your base fuel pressure. Basically, try and keep your maximum fuel pressure under ~90psi.
