2 questions : intercooler and knock sensor
F3600
hey its me again .. :)
Im trying to know where to hook up my knock sensor... there some left over plug on my harness but i think the connector is on the lower harness but i only got the EFI harness so i need to hook it up directly on the wiring Right? wich color from the wiring .. is it white ? i looked trought the fsm but im not sure!
and for the intercooler... im about to get my 2 missing part my maf and dropping resistor... im supa dupa bored to wait for my intercooler .. (and i think i got ****ed by the seller.. ) so im thinking running it withtout intercooler.. is it a good idea.. ?i know they were setup without intercooler in japan.. but just wanted some input
thx again !:)
NeedCAforS13
Car: CA swapped S13 coupe
they used intercoolers in japan :confused: they didn't use a bypass valve or BOV, but they were intercooled. I wouldn't run no intercooler myself, but its like 90 degrees outside :pface
Sean
pulsar gtr
Car: NISSAN VEHICLES
Your detonation sensor has a white wire pin 23 on your ecu , you can run a wire from the sensor to the ecu or you can tap into F9 or F8 plugs on the engine harness
F8 got 7 wiresF9 got 7 wires as well
F8 has these color wires b/w, red, blue/green, blue/red, black/red, white, black
F9 has red/black, red/yellow, green/yellow, black, white, red/white
And don't even thinK of running without and intercooler, you already spend good money on the conversion, be more paitent and wait for you parts I guess and order yourself a nice fmic.
PULSAR GTR
F3600
hoo my bad .. i was thinking they didnt got intercooler :pface well i didnt run it soo its all okay
thx for your advice
