2 Questions for you HiJacker (transmission question)
E7-S14
Car: ess 14 foo!
i have an s14 SR and i think my input shaft bearing or input shaft is going bad
The car doesn't feel any sluggish but has that whining(supercharger like) noise coming from the transmission.
ive consulted many people about this and most say its a bad input shaft/bearingif that's the case how much longer do you think i have on the transmission if its the bearing since the the car doesn't feel any the less sluggish.the trans has about 70k on it.
my other question is about your SR and KA bell housing DIY threadi hve the s14 SR and transa friend of mine has a S14 KA trans.bell housings should bolt up fine without any problems correct?
there was a post in that thread that said i needed to grind somewhere in the bell housing but the poster came off as confusing.
Hijacker your help( or anyones) would be much and greatly appreciated
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Either way, your trans has to come out for repair. It will be just as easy to replace the input bearing because the bell housing has to come off anyway.
E7-S14
Car: ess 14 foo!
boro drift wrote:Either way, your trans has to come out for repair. It will be just as easy to replace the input bearing because the bell housing has to come off anyway.
your def. of easy and my def. of easy are two completely different things
ill first change out my trans fluid first with something betterand i think my transmission fluids low also.
boro drift
E7-S14 wrote:ill first change out my trans fluid first with something betterand i think my transmission fluids low also.
Redline synthetic, your only hope.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I have the same problem. I highly dought a fluid change could repair a bad bearing.
Really? Do you have to buy a rebuild kit or can you buy just the input bearing?
boro drift
supreamS14 wrote:Do you have to buy a rebuild kit or can you buy just the input bearing?
You should be able to buy just the input bearing.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
My trans has the same whine, I figured it was the input bearing too... Though given the miles and abuse it's taken (170k+ over 20 years) I've wondered if the gears are worn as well...
One of these days I'm going to rebuild the while unit, but only if I can get a good deal on a short extension FS5W71C. lol
johnnyballs180
Car: 1990 240sx
same issue here. the whine has been there since i got the car, and i don't know if it's gotten louder or not since. i never want to take that transmission off again.. my pelvis is still recovering.
supreamS14
E7-S14 wrote: how much longer do you think i have on the transmission if its the bearing since the the car doesn't feel any the less sluggish.the trans has about 70k on it.
I have drove mine like this for about 2 months. I hope it won't mess anything ells up if I drive it like this for a few more months.
boro drift
Worst case, it will ruin the input shaft.
E7-S14
Car: ess 14 foo!
welli put new fluid in therePennzoil Syncromeshturns out i was a bout a quart lowwhine is still there. but its not as loud
car feels greatnew clutch/flywheel/2way lsd
im happy.ill drive it till the transmission dies.then ill put Redline MT90 in there.i wanna try that stuff.. everyone seems to swear by it.
thanks for the help guys
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
it's been my experience with Nissan transmissions that the barons than always go bad first are on the counterbalance shaft and usually are the ones in the sandwich plate. If you should go in the transmission at replace all the main bearings
Tulsa_S-13
Car: 1991 SR 240sx
That's the spirit! My SR's transmission makes the same whining sound.
