2 questions about the hatch....
JDM_nismo
Car: 1990 240sx touge monster
well i bought a 90' 240sx and i'm having problems with the hatch. 1st i want to make sure is if a 89 240sx hatch would fit on my car? cause the kid that had it before me made "new" holes for the spoiler and its leaking. i found one in a junk yard on a 89' 240sx with no spoiler and was woundering if there would be no problem replacing it? also how much to you think the cost about?
2nd the pull lever by the driver seat to open the hatch dont work. I have to have somw one stand at the hatch and pull up when i pull the lever.... i took a pick of what can be the problem, but i'm not sure what i need to fix it
the part i have circled just moves up&down when i pull up&down on the lever. any1 have a clue what i need??
thanks for all the help
navysnail
the hatch can be replaced. mine was done a while ago by a local body shop since it had to be painted. you could also do it yourself, its not very hard.
that cable attatches to a release behind that red part to the right of the blue circle. i cant remember exactly what it looks like, but i am sure it is somewere in there.
Red coupe
Car: 92 Nissan 240sx Coupe
89 ad 90 are the same....hell 89-93 I think are the same exept the front bumper and engine...When you replace it you should look for a hatch that doesnt have the stock spoiler either...The stock foam spoiler is infamous for trapping water and rusting the hatch.
JDM_nismo
^^ yeah thats what i'm gonna do, the hatch has no spoiler, thats why i want it, cause the foam spoiler is kinda dumb looking to me... hopefully i can get it soon, thanks for the help
Nick240sx
Car: 2009 Ford Fusion SE Sport
well ironically the same thing is up with my hatch, the lever doesnt work either unless theres someone standing at it when i pull the lever, ill just use this forum as advice. thanks
hek1620
Car: '89 240sx
i used to think my pull lever didn't work. but i found out the other day that if u pull it up and leave it where it stops on the way back down instead of pushing it back down u can go to the hatch and lift it urself. maybe it's just my car.
