MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sun May 20, 2007 7:45 pm
Wow...50k on a 93. Nice find. Mine just turned over 226.
Is it an SE or a GXE?
Either way, usual suspects for rough idle are injectors, plugs, MAF, etc.
I'd start by checking the plugs. If they're not NGK, that may be your problem. Plugs like Bosch or other alternatives to OEM NGKs tend to cause rough idle and hesitation in our cars.
As for the transmission, with only 50,000 I doubt you're in danger of loosing it. However, since it IS 14 years old, I suggest getting the transmission flushed if you haven't done that already. New, fresh fluid can make a huge difference.
