evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Nov 22, 2008 7:51 pm
what was your et at the 1/4 mile? I've only ever seen 1/8 and 1/4 mile drag strips but I know canada does a shorter run, stock n/a in the 1/4 i believe would be in the 16 second range
as for shifter bushings, IIRC the shifter bushing s are the same as the ealeri cars, on which case chrysteer door hinge bushings are a great fit, you can get them at the help section of your local parts store, or if you prefer, courtesyparts.com or zcarparts.com should both have them
