2 question if they could be answered
kim
Car: 90 240sx, 97 M3
I just found a Hicas rear sway bar for $25 I wanted to know how many mm is the sway bar? I don't have anything that could measure it. I want to get some Energy suspension bushings for it.
Next question, I see alot of post saying that you can use the KA clutch for the CA engines but doesn't say which KA engine (KA-E or KA-DE) I looked at search but just says "use Ka clutch".
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
I'm not certain about the sway bars size but I have heard that the Hicas models are thicker.
The E and DE KA series motors use the same clutch and flywheel.
EDIT: I know very little about the CA so don't take this as meaning they fit it. Specifically the flywheel.
Modified by Veriest1 at 2:38 AM 2/25/2005
kim
thanks for the reply but I usually see on clutch application charts one type for the 89-90 and then I see the 91-up?
Oh and the Hicas swaybar is almost double the size of the stock swaybar
Veriest1
Car: '96 BMW M3
Yeah, many companies seperate their clutches between the SOHC and DOHC. Check out enjuku racings site and you'll see some who don't.
Sorry about the slow reply. I completely missed yours.
