2 problems!
Shaftinator24
Car: 1990 300zx TT (Barbarella or Babs for short)
Alright so here are the two discoveries I have made regarding the weird buzzing noise and the reason my steering wheel is so shaky on my Z right now.. first and foremost the buzzing noise is my fuel pump dying out on me. So I need a new fuel pump what's a good fuel pump for the Z? Second, I know that if I fix the tie rod that I'll finally be able to fix my alignment. So that's the situation guys. Any advice on the fuel pump to go with?
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
OEM
Here is an article on flow analysis of various pumps. You can get a Walbro GSS315 or 341 that "tests" to pump better than Nissan OEM. I have used the Walbro 255 in my son's Supra and it has been running well for 7 yrs. So, you make the call. If you can get one that bolts up properly and doesn't require a ton of modification, then maybe. But, if not, go OEM.
http://www.stealth316.com/2-fuelpumpguide.htm#j5
NolimitZ32
Walbro is cheaper than OEM new and works fine but if you dont mind spending the money go OEM.
