2 problems
General discussion area for the L30-chassis Altima
kennedy33
Car: 2001 Nissan Altima
I have a 2001 Nissan Altima. I am hearing this gawd awful screeching noise from what seems to be the fan assembly. It only screeches when the ac is on. I just replaced all my belts about 2 months ago and the screeching is not coming from the belts. When I'm under the hood and give the car some gas, the screeching starts. It's VERY loud and lasts only a couple of seconds. Any thoughts before I replace the fan assembly?
2nd question is that my fuel gauge is not working. I asked a technician about this and he said there could be 100's of reasons why it won't work. Any help is GREATLY appreciated. Thanks and love the site.
Jerry
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you spun the fans by hand? My brother has a similar problem but it turned out to be his water pump bearing gone bad.
kennedy33
I'll try that when I get home.
kennedy33
Well, I spun it and it spins freely. When I had my wife start the car up and turn the ac on, the sound was there and the fan didn't start turning right away. Should the fan start turning as soon as you turn the car and ac on?
kennedy33
kennedy33 wrote:I have a 2001 Nissan Altima. I am hearing this gawd awful screeching noise from what seems to be the fan assembly. It only screeches when the ac is on. I just replaced all my belts about 2 months ago and the screeching is not coming from the belts. When I'm under the hood and give the car some gas, the screeching starts. It's VERY loud and lasts only a couple of seconds. Any thoughts before I replace the fan assembly?
Jerry
1st problem was my ac belt needed to be tightened.
2nd problem was my fuel sending unit ($13 part)
Rev_D21
All good now?
Return to “2nd Generation Altima Sedan (1998-2001)”
