tonyh »
https://forums.nicoclub.com/tonyh-u102694.html
Fri Aug 01, 2008 11:58 am
I have a '95 J30,1st problem,no odometer,the speedometer works but no odometer.2nd problem,at initial start up the vehicle has a lot of power,but after about 5-10 min.,the vehicle becomes sluggish,almost like if it had a plugged fuel filter,out of time or a problem with the transmission. The fuel filter is 3 months old/new I'm not sure on the timing but it does not ping on hard acceleration and the trans has clean fluid in it. I bought the car from a neighbor who had it parked for 2 years,I had to replace 1 head and had the other rebuilt due to poor maintanace by the previous owner. The timing marks are where they need to be,I'm just not sure on the timing since I did'nt have a scanner to check it with.I should also mention that the check engine light is on, and at times it goes off. Any suggestions would greatly be appreciated.
