DrIfT_FoReVeR »
https://forums.nicoclub.com/drift-forever-u16639.html
Thu May 20, 2004 3:27 pm
i used to have that sound under my hood when my RPM's got up to about 3000, and then anything after that, it would stop. so i opened the hood and played with the throttle body and revved it until i located the source of the sound, and it was the exhaust manifold shroud/heatshield. the welding had either broken off or warped off of one side, so i just shoved a 6 inch gutter nail in there to fill in the hole until i got a new exhaust heat shield from nissan.
this is only a temp fix, but it does work and it wont sacrifice performance...one bit of advice though, don't use anything made out of plastic or wood...bad news...
