2 problems, car dies with clutch in and a loud rattle
sweetdreams6t9
Car: Nissan 300zx 2+2 N/A
Hey guys, Ive got two issues.
Number one... So like when I'm driving, if I push the clutch in the revs will drop and the car will shut off. It doesn't happen when I shift, just when the clutch is in for any length of time. It's kinda dangerous... I was wondering what could be the cause.
Second, there's this like, really loud rattle from the back end. Its not the exhaust. You can hear it when I'm driving and I hit a bump, or there's any unevenness of the road. I'm so confused as to what it is :(
Thanks for the help!
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Engine mod list for diagnosing the stalling please.
The rattle could be your sway bar bushings, the heat shield for the cats has worked loose or a wheel bearing.
nissanfreak12
Car: 92 300zx 2+2 TT
How old are your struts? they like to rattle when the are done. Also check the all bolts/nuts connecting, had a friends car have the same issue, couple shops tried to screw him and all it was a loose bolt
