par2za wrote: the variables are rpm, knock ,temp and throttle. so the system allways controls timing dont forget also on this system timing is used to control small variations of idle speed if it cant the iac(ide air control) will then be used to make the changes. that means if you're going to make any timing adjustments you need to unplug or jump somthing to let the ecu know not to control timing. i will be back at work on tues and will look it up to see what the prucedure is to adjusting timing
Timing is also affected by signals from the CAS, MAF, speed sensor, throttle valve switch, gear switch, AC switch, power steering oil switch and battery voltage. *RPMs are not an input to timing*. Timing is not used to control small variations of idle. I have hard copy FSMs from 3 different model years, including for your '95, that all say the same thing. If the resource at work says otherwise, it's wrong and you might want to make a correction in it. While I can really appreciate your wide knowledge base as a tech, realize that this car is the only car that I, as well as others here, are truly passionate about.
