Running the same plugs as you. My main problem is how rich I am running, lol. I used to hit 1.7 60' all day long, and that was on slicks that were so worn down there was no evidence of the wear indicators at all! ha ha. Yeah, I'm running 26x8.5x15 ET's, but I just received a set of MT 255/50/16 Drag Radials, so we'll see how they do on the 18th. My buddy has a 10.8 WS6 trans am and he hits 1.4 60' on his MT 275 drag radials. Oh, and I've been launching between 6 and 7k RPM's...kentuckyslider wrote:What plugs are your running? I run BKR8EIX iridiums gapped at .025. I have a JWT tune and cobra MAF with 72lbs injectors and love it. I get 11.2-11.5 afr at WOT. I have stock coils and never have a problem getting spark. I think you are just running to rich. Get your 60' down in the 1.6-1.7 range and you'll be in the 11's for sure. You do run the 26x8.5 MT Et drags right? I launch at 7000rpm with the drags and it doesn't spin at all. I honestly like the 235/60/15 drag radials better than the wrinkle walls. They're easier on the clutch and the transmission and you don't gain but maybe a .1 second on your 60' with the drags. Plus you can drive to the track on your radials.
Thanks for the link man! I'll try to mess with it when I get some time, lol. School is kicking my @ss at the moment, ha hacrashcourse wrote: You did say you had a power fc right? Tuning is easy once you figure it out.
http://paulr33.skylinesaustral...q.htm
It took me a while with a good friend or my girl friend but I got it pretty close . If all you have to do is add fuel right now than that will be real easy.
Lol, I love it honestly, and I'm sure I'll love it even more when I get everything tuned up correctly! I start building boost around 3500, and hit full boost between 4k and 4200 rpm's. That's at 20 psi... As for traction... get sticky tires! haha, until I put the drag radials on, just going normally, I'd lose traction in first and second. And the top end, is where this setup really shines, lol. Between 4200 and 7500 on stock cams, it just keeps going!crashcourse wrote: I hear that ... I am currently running a t3/t4 60 trim at 18psi and it is super laggy untill about 5000 with 272 cams, stock cams it comes in a little sooner but not much. .. I am thinking of going with a gt30. what is your opinion? fun? loss of traction? thats what I am looking for. That hard spool like a 28 has but I want to hold it up top.
I would consider this turbo. I have been hearing from several sources that it can't be beat. http://www.timsturbos.com/S256.htmlcrashcourse wrote: I hear that ... I am currently running a t3/t4 60 trim at 18psi and it is super laggy untill about 5000 with 272 cams, stock cams it comes in a little sooner but not much. .. I am thinking of going with a gt30. what is your opinion? fun? loss of traction? thats what I am looking for. That hard spool like a 28 has but I want to hold it up top.
