fueler »
https://forums.nicoclub.com/fueler-u54519.html
Tue May 18, 2010 5:06 pm
yeah actually thats all you can do is lift springs with stock struts... (struts in front, shocks in rear)
different companies make different color struts but they all have the same extended and compressed lengths.... the only differences is damping.
The only question is, do you want to use the existing old struts you haveon there now, or do you want to put NEW replacement ones in since you're gonna have it all taken apart anyways?? Cause it would actually be slightly LESS labor to put new springs with new struts at the same time, since you wouldnt have to disassemble the old spring/strut assemblies, just pull the whole assemblies out and throw them away.... its more work to actually disassemble your current setup, and only install springs on your existing struts...
If you buy new struts, you'd only be paying for the parts, labor should be the same or even less. (that is, if youre paying someone to do it)
