2+ inch lift
Qxx4
Car: Infiniti qx4
guys can i get more than 2 inch lift in the front with out screwing up the cv boots. i have read many articles but couldn't get a definite answer :gotme
fleurys
Car: 2001 Pathfinder , Locked and loaded !
If you install wheel hubs and keep them unlock most of the time (and lock them when you offroad, you will keep your cv boots for a long time. I have been running the same boot for many years now... I have also installed thermoplastic boots from rockford, which are thicker than the regular neoprene boots.. I ran between 2.5 and 3" in front with this setup without issue.
Qxx4
Car: Infiniti qx4
Yea i thought about it in the same way just wanted to see if anyone ever did it, but for the hubs i have automatic transfer case wouldnt that be a Problem?
fleurys
no problem for the atx14a transfer case (with the auto mode)... Just do not leave it at AUTO or 4wd when the hubs are unlocked.
Qxx4
Car: Infiniti qx4
Thanks man :dblthumb:
