2 inch lift for a 2006 infiniti m35 to fit larger wheels
kepdee
Car: 2006 infiniti m35base
I'am trying to figure out where or how can i raise my suspension 2 inches on my 2006 infiniti m35 ,i have 22s that went right on but iam trying to upgrade to 24s so it would be a great help on what i need to purchase like bigger shocks or springs and where can i order them from
Reason: Added info to title
szh
Car: 2018 Tesla Model 3.
Hi! Welcome to NICO.
I am going to move this to the M forum at NICO ... you may get an answer there.
Z
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Smh. :facepalm: :slap:
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
First I'll say I have no idea of the practicality of this, or the structural pit falls.
With that said, first get coilovers and extend them.
For the front, you can get strut mount spacers (or make them which shouldn't be hard), then you'd need adjustable control arms.
For the rear you'd have a couple options
A/ If you stay stock you'd need the same spacers, but you'd also need a spring spacer for the perch or something to sit in the perch to compensate for the height you want. This will become problematic because the perch is not that deep and I believe that the spring will slip out with use. Also it will be a hell of a time getting the perch back in place, if at all possible, after making that modification. Also, I think you'd have to make some type of modification to the "perch hinge" to lower that a little for this to truly work...use a kind of extension bar to drop it a little.
B/ get a full strut like the front to eliminate the need for the perch and simply do the same as the front. I don't think they make ones for the rear except for coilovers, so you'd need a coilover set.
That's my theory on raising the car to hopefully start the thinking.
EniGmA1987
Car: '06 Infiniti M35 Sport
The car already needs a drop when running 22's because the wheels make the car way too high. I cant even imagine wanting to run 24's and especially raising the car even more on top of that. Are you going to take turns at 1 mph?
Larz
Car: 2019 Q70-L RWD
Where I live, there is a company that specializes in this sort of work. I see lots of M's and other cars on surprisingly large wheels. I can't imagine what it does to the ride quality and I try never to be behind one of these cars when approaching bumps, railroad tracks, etc because they have to drive at 5mph when encountering them. Here are examples:
https://www.youtube.com/watch?v=D5ie5ndP-0Q
https://www.youtube.com/watch?v=4MvMZjeT6ug
http://youtu.be/pam_-dLG3io
Just an opinion from a bloke who thinks even 20's look one size too big for our cars.
EniGmA1987
risingson
Car: '04 Infiniti G35
Actually the right set of 24s can look pretty baller on these cars. The cars are big enough to pull them off... I think 22s are the perfect fit and those 26s look like trash.
https://www.youtube.com/watch?v=lZTGYPIlonw
https://www.youtube.com/watch?v=_VpZ0c5gDHo
speedracervroom
i like 21's they fit our body perfect. even tho I'm going to 20s now
Remedii
Hey I was wondering if you figure out what all needed to be done for your 24s to fit with out cutting anything?
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Yea Larz is correct you see a lot of cars that shouldn't be on 6's. I live in the Tampa bay area there was on 06 chameleon g35 on 6s a while back.
https://youtu.be/GnUrM2f1Qu4
Here's the g35 I haven't seen an M personally on anything bigger than 20' but I'm sure it can be done. I'm sure Ace whips can help. Where are you located?
bicsintegra
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
that might be the ugliest thing I have seen since Lil yachty
jonlex99
Car: 06 Infiniti M35X, 06 Kawasaki Z10r, 06 G35s coupe 6smt with the 19 inch forge wheels. 02 Lexus LX470
It each his own.
maufknced
Car: 07 m45
No need for a lift just get the right offsets/widths. I've seen one on 24's and it fit perfect more or less with no suspension modifications.
Non educated guess it was on front-24x8.5 - 30-40et Rear 24x9-10 - 35-40 offset. He never replied with the sizes.
A lift would be a horrible idea...
Skwirl865
Car: 07 m35
Has anybody put 24s on one yet?
Ilya
Skwirl865 wrote:
Wed Jan 31, 2018 5:36 pm
Welcome to the forum.
1) Please don't ruin your car with 24's...
2) If you MUST ruin your car with 24's...see LITERALLY the post above yours.
Skwirl865
Car: 07 m35
They said uneducated guess. I don't wanna order the rims and be stuck if they rub. I don't want to lift it and won't unless absolutely neccessary but want to know how it can be done and parts/cost before I start the ordering process
EdBwoy
Skwirl, is it possible for you to go to a rim shop and do some test fitting? They usually have a way to test, I believe or for some of them they might have a few wheels to try on.
I understand what you're trying to do, but the largest documented size I've seen in our platform is 21". Maybe we can learn from your experience.
Skwirl865
Car: 07 m35
I wish there was. I live in a city just big enough to be called a city but still small enough to make anything custom, an "on your own" kinda process. There's a rim rental place but they don't even carry anything that big. No real custom shops that do that kind of work or anything.
I've came across people who have put 22"s on one with no modification so if I can find an option that will allow me to raise it 2" if it turns out it has to be done, I'll feel safe ordering the rims and of the lift ends up being required, I can then order it and go that route. I'll definitely post what the situation ends up being and how it works out. I just need somebody to point me to my 2-3" safety net lift option.
Skwirl865
Car: 07 m35
I wasn’t sure about the lifting so I just went with the 22”. Figured I would come let everybody know for sure that 22s will fit with no rubbing at all. I have 3 sons 17, 16, and 10. One plays football and I have yet to run at any speed even with all of us in the car on the highway and I can turn all the way with no rub as well. The ride is actually really good. It wasn’t so good at first when the tire pressure was 35psi but i hit a pothole and it was horrible so i increased the pressure to 44psi and the ride smoothed out and the pothole tolerance was a while lot better.
I had worn tires on factory rims the ride was worse than my 22”s are now by a good bit and I have the cheap tires on here so there's not a lot of change in the ride on regular pavement.
Hopefully this will help somebody in the future.
Here’s the wheel and tire size I can confirm, works.
My wheels are 22x9 with a +30 offset and the tires are 245/30/22.
No fender rolling or other modification, factory suspension
Skwirl865
Car: 07 m35
22x9 +30 offset 245/30/22
Skwirl865
Car: 07 m35
I'm trying to post a pic but for some reason it won't show up
EdBwoy
Skwirl865 wrote:
Mon Mar 05, 2018 4:42 pm
Does it give you the option to post the BBCode rather than just a link? If it does, just post it up below and I'll edit it into the previous post.
And... thank you for sharing your results with us. I am sure people are curious about these things.
https://m.imgur.com/gallery/5ZqyK
Skwirl865
Car: 07 m35
Skwirl865
Car: 07 m35
22x8.5, 35 offset with 255/30/22 bolt right on, no modification and no rubbing. Image
