yessir240 »
https://forums.nicoclub.com/yessir240-u24652.html
Wed Dec 12, 2007 8:38 am
gosh, all I see is complete noobness across this thread. Lowering your car 2 inches shouldnt really do too much to your alignment. I had my s14 with Eibach sportlines mounted on kyb dampers. it was like a 2inch drop or prob more, and well I had no problems with camber, so there was no reason to fix the camber issues. The fact is it will look gay imo so you should just do coilover and slam your ****, then you will need camber adjustment in the front and rear, and also toe adjust in the rear. Then again I could go into a whole rant about performance wise you get more steering angle out of a closer to stock ride height because of the angle of the tie rods. All in all asthetically i stand by what i said , even with the 17s it will look weak comparatively.
