tazjig »
https://forums.nicoclub.com/tazjig-u1328.html
Thu Apr 29, 2004 1:43 pm
OK, i really need help here. I finally got my swap done and every thing was going great, running beautiful, so i drove it to my buddys for the first run and it was fine. So we went to hook up my aftermarket tach, and stupid me did not research how to hook it up so i just figured the signal wire for the tach ran to one of the coil wires and nothing was working, duh.. but..... while i was doing this i started the car up and the wire that i had spliced to the coil shorted out on the back of the instrument cluster and the car died and wouldnt start back up. So i was so sure that it was the ignitor becuase it gets power to the side with 4 pins when the key is on and i cant get power across the ignitor at all, even when it is cranking. So i ordered an ignitor, and it didnt work so i did a resistance test and to me it seemed like the chip was bad so i ordered another and still no spark. both ignitors give totally different resistance readings and none of them seem right, is there a chance that i could have gotten two bad chips? is there anything else i should check? sorry about the long post but i really need help because summer is just starting and i have no car, please help, i have searched everyhing. Thanks.
