2 hoses going to the radiator what are they?
rubdog
Car: 95 Infiniti Q45t sitting of Dubs
Can anybody tell me what are these two hoses. on the passanger side of the radiator not the driverside I know these are from A/T transmission hoses.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
They carry the trans fluid to the trans cooler (heater) built into the radiator....
Do yourself a favour, and get an aftermarket trans cooler. Hook these 2 hoses you speak of up to it, and your transmission will thank you by lasting longer.
EDIT: My passenger side is opposite to yours, hence the confusion. sorry.
Q451990
I'm pretty sure the 94+ had two transmission radiator tank "coolers" - so both sides have hoses going in and out of the radiator end tanks.
Heath
rubdog
Hi, I was asking because I was going to replace my radiator and the one I got of the forum did not have the connections for the passanger side it only has to two brass connections on the driverside. Does anybody know if I can still install this radiator without the passangerside hoses?
96Qowner
Car: 1996 Q45
The extra two lines are just for an additional in-rad transmission cooler - earlier models just had the one "cooler" - just a simple tube in the radiator. So, you can just hook up the lines from the transmission to the two you have.
But ... you should seriously consider installing a genuine transmission cooler as long as you have everything apart. These transmissions aren't known for their long lives. An auxiliary cooler will help longevity a lot. Here are some threads on transmission coolers, along with pics and an explanation for the 2 vs 4 lines on the radiator:
Mobil 1 & Trans Temp
transmission Cooler
TRANS COOLER THIS WKND
transmission Cooler - G50
Adding An External Transmission Cooler - Q45
rubdog
Hey this is exactly what I was looking for thank you very much 96owner!!!!!!!!!!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
rubdog wrote:Hey this is exactly what I was looking for thank you very much 96owner!!!!!!!!!!!!!
Ain't the SEARCH function wonderful?
