2 fuel pumps?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
crankor
Car: 2011 Infiniti FX35
I wanted to clean off the gas gauge sensor and since theres supposedly two fuel pumps, do both have their own float sensor thing or just one? I only ever see videos of people taking out the passenger side one for that
TrimDude
Car: 2009 Nissan Sentra 2.0
1986.5 Nissan Hardbody SE
1995 Nissan Pathfinder XE
2017 Nissan Quest SV
There is only 1 pump. The driver's side has a float/sending unit that lets the pump know what's going on with that side of the tank so it can pump accordingly.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's only one pump in the tank, the other is just a level sender and pickup so you get a correct reading from the saddle tank and can pull from both sides. The senders are series-connected so they produce an average of the two wells.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
