#2 Cylinder no Fuel (I THINK) on 93 300zx tt new parts
History
1993 (2nd owner I bought it with 13K miles in 94) 300zx TT Stage III ,78K miles on it. In the last 5 years I only put 4K miles on it. It has been in the garage for years.
I decide to start driving it. So I added (with LOTS of help from Glenn McCall Dallas,TX) I paid him to put all the parts on. (Not to trouble shoot).
1. New 1993 Wire harness
2. 300 Deg Fuel rail, 740 cc Nismo
3. Blitz Spec R
4. New AAIV
5. Fuel Pressure Regulator
6. Nistune Chip
7. New O2 Sensors
8. Water Bypass,
9. EGR block off, Emission removed
10. SZ 2.5 Down Pipes
11. New Plugs PFR6B11B
12. New Motor Mounts
13. New PCV’s
14. New Fuel Hoses, and some Vacuum lines
Test that I have done.
1. Replaced Coil pack (and even Swapped with working one)
a. Pull out and even looked at spark on Plug (while car was running)
2. Test voltage on all Injectors while car was running (14V )
3. Ohm ALL Injectors (most of them read 14.0 – 13.3 Ohms)
4. Compression test all Clys each about 142-145
5. Swap #2 Fuel Injector with #4 Inj
a. Then pulled Coil pack while car was running on #2 (car still did not change sound)
b. Pulled Coil Pack on # 4 (car did change sound)
6. Held Screw Driver on injectors to hear sound, #2 not loud (maybe sound from all others from fuel rail), all others I hear Twak, Twak Twak..etc
7. I even started the car with no coil pack in #2, when pulled #2 plug real quick (after I shut off the car) to see/smell gas on the plug and no gas.
Do you all have ANY idea what I should do next?
I’m thinking, ECU,PTU,CAS, on maybe even rechip with Nistune (don’t know it what order) or getting some type of Digital Compression tester (if there is a good one)
Here are some Pics
http://www.4shared.com/photo/gckNfzOk/2spark.html ]
http://www.4shared.com/photo/W1xyIS0b/2SparkPlug.html ]
http://www.4shared.com/photo/XNaZUA7K/4SparkPlug.html ]
http://www.4shared.com/photo/-XfqbOI5/allCyls.html ]
http://www.4shared.com/photo/SH5d9KVi/motor.html ]
http://www.4shared.com/photo/VeWLMg4I/ohms.html ]
http://www.4shared.com/photo/uuzv68Zh/plug2.html ]
http://www.4shared.com/dir/asvGfwRG/300zx.html ]
Cyl Comp test, Ohms on each Nismo {yes, on a paper towel }, Show spark from Plug, Show color on NEW plugs (see #2 color {Dark} and #4 color is the same as all others)
More notes
Ohms on each Injector are 1=14.0, 2=13.3, 3=13.0, 4=14.1, 5=13.0, 6=14.0
( I guess I need to short out leads then mins from result’s above from meter, I just now thought of that…hum) I really don't know what Ohms are suppose to be on new Nismo 740's??
Thanks for everyone help on this. I will POST what fixed it.WHEN I FIND a FIX.
My Christmas gift i want is... for me to drive my car :O)
