Lazyron007 »
https://forums.nicoclub.com/lazyron007-u44086.html
Thu Aug 24, 2006 5:35 am
Sorry. Here's all the information.
400 Watt 2 Channel Amplifier Variable Built-In Crossover system: LPF, FLAT, HPF 50Hz - 250Hz Low Pass Filter 50Hz - 250Hz High Pass Filter High Level Input 2 x 100W Rms @ 4 ohms Stereo 2 x 150W Rms @ 2 ohms Stereo 1 x 400W Max @ 4 ohms Bridged Dimensions (H x W x L): 2" x 9.6" x 8.8" Variable Bass Boost 0 - 18dB @ 45 Hz Power/Protection LED RCA Line Inputs & Outputs Thermal/Short/Overload Protection Circuitry Variable HPF/LPF Crossover Adjustable Input Sensitivity Full MOSFET Circuitry 60dB Channel Separation 22K Ohm Input Impedance 200mV - 4V Input Sensitivity Frequency Response: 20Hz - 20kHz THD <0.05%
FOR THE FRONT DECKKenwood KFC-1380ie 5-1/4" 2-way speakers (pair) » mica-injected polypropylene woofer cone with rubber surround » PEI balanced-dome tweeter with Image Enhancer 2 baffle » power range: 2-35 watts RMS (160 watts peak power) » frequency response: 45-20,000 Hz » sensitivity: 91 dB » top-mount depth: 1-7/8"
FOR THE REAR DECKKenwood KFC-1660S 2-way car speakers for 6-1/2" and 6-3/4" locations (pair) » mica-injected polypropylene dimpled woofer cone with cloth surround » PEI semi-dome tweeter » power range: 2-35 watts RMS (170 watts peak power) » frequency response: 35-22,000 Hz » sensitivity: 92 dB » mounting tabs for use in 6-3/4" openings » top-mount depth: 1-3/4" » warranty: 1 year
