2 CA18DET Questions
02 Black Spec V
Car: 2002 Nissan Sentra SE-R Spec V
First off I did search, I didnt find jack
1st off, I am going to be buying a s13 soon, and I plan on doing a CA18DET swap. I have been looking for a How-to or a list of what will need to be done and I cant find one. Can someone help out?
Also, whatever happened to that list of CA18DET - DE parts crossover list? I can find it, I though it was on this forum...
DriftinNC
Car: Sr datsun 510
http://www.ca18det.org/parts.html go there for the crossover parts
F3600
Search a Faq for sr20det its almost the same.. well its the same as a sr20det swap.. if you get a 89 90 you will need to bend power sterring line but that all..
02 Black Spec V
that sounds good. is it the same right down to the wiring? Or is there some other things I need to look forward to for that?
Also, is there a CA18DET FMIC kit? or do you use the sr20? thanks
Nunook
Ive seen FMIC for the ca18det specifically. The only thing i think that would be different would be the pipes on the engine side of the bumper.
