link239 »
https://forums.nicoclub.com/link239-u119047.html
Thu Oct 30, 2008 4:01 pm
2 of my right rear wheel studs broke off when I was trying to remove the spare tire I had on my 2005 G35 Coupe. in the process of tightning the lugs, I must have stripped them. After attempting to try to remove the hub, I realized that it is pressed in there and I can't remove the hub to take to the machine shop and have new studs pressed into the hub assembly without having to remove the rear axle. A shop quoted me $675 dollars to replace the 2 studs because they said they have to remove the whole rear axle to have the studs pressed in, which I think is insane. Is there another option here where I can do it myself and have new studs pressed in there and not have to pay that rediculous money. A quick response would be awesome. Thank you.
Modified by link239 at 8:38 PM 10/30/2008
Modified by link239 at 8:42 PM 10/30/2008
