.2 bar of vacuum at idle?
terry_240sx
Car: '93 240sx hatch
hey guys i need some help
i recently put in a t25 turbo, had fun with it, and the seals went out so i replaced it with a gt28
but with this t28, which im still breaking in, it idles at .2 bar of vacuum (which is pretty close to 0)
my t25 idled at the same vacuum it did before i put the turbo in
is there something i did wrong or something??? :tisk:
thanks in advance
*Berto*
Car: 89 nissan 240sx
just check your vac lines... probably just somethings not hooked up, or a hose is damaged somewhere
terry_240sx
*Berto* wrote:just check your vac lines... probably just somethings not hooked up, or a hose is damaged somewhere
yeah that's what I initially thought
i checked all of the lines though and nothing appeared to be out of order
the car still drives perfectly fine though, it just bugs me :frown:
*Berto*
get a friend to let u use his gauge,, never know that could be it... if its running like it use to then that could be it.
