InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Tue Feb 07, 2006 8:27 pm
The car has camshafts in it, or so I would assume it does, if it runs.
Compare the lobe center angle of the current cams to the installed exhaust cams, as long as that matches up it will work fine.
If you don't know what a lobe center angle is, you probably shouldn't be d!ck with your camshafts.
