2.5s and 3.5se Coupe rim specs
LolMang
sorry about this stupid question :\. I looked at LongBeachCoupe's rim thread but it said nothing about whether the offsets were the same in a 3.5 as a 2.5. Can somebody clarify?
ESP
Car: 2008 SexyBlack A/C
Offset should be the same...+35 to +45 from what I've understood. You can get rims with a higher offset ( >+45) but then you'll need lug adapters (NOT spacers...I'm afraid of spacers...)
beeristasty
Car: 07 Altima 3.5 SE
ESP wrote:Offset should be the same...+35 to +45 from what I've understood. You can get rims with a higher offset ( >+45) but then you'll need lug adapters (NOT spacers...I'm afraid of spacers...)
I'm running +48 on 18x8s with 245/45/18s - without rubbing or any adapters.
Depends on offset and rim/tire width. So +60 on 7" wide rims should fit, if my math is correct. Not that I'm encouraging anyone to try it.
