2.5s 6mt.. going to instal injen
Shift_Altima
Car: 2008 altima coupe 2.5s 6 speed
Hey guys. I ordered the intake for the 6 speed 2.5s. Ya.. I know.. it shouldn't fit but I figured I might as well try. Keep you guys posted because I'm installing it satruday afternoon. Let's see what happens.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Which altima do you have?
Shift_Altima
08 coupe I-4 6 speed
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
Good luck! Pulling it off would make a lot of other folks happy...
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
I'm sure as long as the bends of the pipe allow for the intake to lay in correctly, i'm sure securing and mounting will be the least of the problems. It may take a little engineering on the end users part.
Shift_Altima
Ya. I really don't see it beinga problem with the mounting. If I do i'll post pictures and show what I did.
Shift_Altima
Had to improvise a slight bit but IT WORKS!!
Sacky2.5
Car: 2008 Nissan Altima Coupe 2.5S 6MT + Premium Package
where be dem pics!?
2.5s 6mt here itching for an injen too!
Shift_Altima
This is what you have to do. I'll put up pics when it's not so damn cold. But the step where you mount the intake. You will CLEARLY see that there is a hook type thing where the brass vibramount is and theres no way it will fit. Take out the screw that came with the car and use one that is about half an inch longer. That will give u space to mount the intake. I put a piece of rubber to hold the intake in palce. Then I continued with the regular steps. Ill post pictures soo.
mastersapo
Car: 2008 2.5 S Altima Coupe 6MT
Bump for pics, just bought a 2.5s MT coupe. Lookin to see if any of the other intakes mount well or if the injen with extended screw is only option.
Shift_Altima
Ur going to have to use a longer screw. That's all u can possibly do. If u want pics ill go take some..
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
mastersapo wrote:Bump for pics, just bought a 2.5s MT coupe. Lookin to see if any of the other intakes mount well or if the injen with extended screw is only option.
yes the fujita mounts perfectly on the 2.5S with Manual transmission
mmadore118
Car: 08 Nissan Altima Coupe
i have it on mine and i got the longer screw, it works greatyou'll have to trim the foam around where it will go but after that its fine
