2.5l recall information
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
NISTECH
copy of peices from a big nissan campaign important section in here on mods. read it before takin car in. this is a big recall and most dealers will not do it on a drive in basis. You will need to make an appointment due to the time it will take to do it. If you decide to wait while they perform the initial inspection , pack a lunch cause your gonna be there awhile. 3 to 4 hrs if they start when you drive in. and we all know they dont start on your car when you get there.
CAMPAIGN BULLETINReference: NTB03-070VOLUNTARY RECALL CAMPAIGN
ALTIMA AND SENTRA QR25DE ENGINE EXHAUST PIPEHANGER PIN AND PRE-CATALYST
APPLIED VEHICLES: 2002-03 Altima (L31),QR25DE Engine 2002-04 Sentra (B15), QR25DE EngineAPPLIED VIN Altima: 1N4AL11**2C100000 - 294952 1N4AL11**2C700001 - 719020 1N4AL11**3C100003 - 311983 Sentra: 3N AB51**2L700019 - 730181 3N1AB51**3L716572 - 736783 3N1AB51**4L727627 - 730593 3N1AB51**4L736618 - 738436
NOTE: Use Service Comm to determine campaign eligibility and to obtain thevehicle-specific PNC code.
INTRODUCTIONNissan has determined that some 2002-2003 model year Altima and 2002-2004 model yeaiSentra vehicles equipped with the 2.5 liter engine have defects that relate to motor vehiclesafety. For 2002-2003 model year Altimas, there is a possibility that the exhaust pipehanger pin may catch debris from the road that could be ignited by contact with the catalyticconverter and cause a fire. In addition, for 2002-2003 model year Altimas and 2002-2004model year Sentras, there is a possibility that certain engine operating conditions maycause damage to the pre-catalyst. Material from inside a damaged pre-catalyst could enterthe engine and result in increased oil consumption. If the engine oil level is not checked ona periodic basis and drops below the low level, and the driver continues to operate thevehicle ignoring noticeable engine noise, engine damage may occur which could result in afire.
NUMBER OF VEHICLES POTENTIALLY AFFECTEDThe number of vehicles potentially affected is approximately 360,000. OVERVIEW OF REPAIRExhaust Pipe Hanger Pin:• The exhaust pipe hanger pin is shortened on 2002-03 Altimas, except those that werealready repaired. This repair is NOT necessary on Sentra vehicles.ECM Reprogramminq / Pre-Catalvst / Exhaust Heat Shields:
• ECM reprogramming is required to prevent future damage to the pre-catalyst. A specialreprogramming card is available that contains ECM reprogramming data for allmodels/engine/transmission configurations affected by this campaign.
• The exhaust pre-catalyst will be tested to determine if the pre-catalyst needs to bereplaced.
• The exhaust pre-catalyst will be inspected to determine if more extensive repairs areneeded, that, for a limited number of vehicles, may include engine replacement.
• Installation of Heat Shields on the exhaust system is required.Use the "Repair Flow Chart" in the Service Procedure to determine the complete repairprocedures for a specific vehicle.
SPECIAL CUSTOMER ASSISTANCE FEATURES
Customers should be informed that: A. The basic repair for this campaign should take approximately 3 hours to complete.
B. A limited number of vehicles affected by this campaign may require more extensive campaign repairs.
C. If more extensive repairs are required: • The repair may take up to 5 days to complete.
• Car Rental Assistance is available upon owner request and is to be provided free of charge to the customer.
INFORMATION REGARDING ENGINE & EXHAUST SYSTEM MODIFICATION(s)
Some vehicles may be presented for repair that have been modified using non-Nissancomponents or in a way not authorized by Nissan. Vehicles that have minor or cosmeticmodifications (such as a modified air filter/intake system) will be eligible for this campaign,as long as the modifications do not affect the dealer's ability to diagnose and install thecampaign parts in accordance with this bulletin within the allotted time(s).Owners of vehicles with more extensive, non-Nissan approved engine and/or exhaustsystem modifications may be responsible for bringing the vehicle into a condition thatallows the campaign procedures to be followed and the repairs completed. Extensivemodifications to these systems may make diagnosis (an essential part of this campaign)and the installation of campaign parts not possible. In such cases, the engine/vehicle mustbe returned to an appropriate condition in order for the campaign repair to be performed.For example, the following Original Equipment Manufacturer (OEM) parts must be installedand functional: • all oxygen sensors • the pre-catalytic converter • catalytic converter • engine (ECM) control moduleOnce the campaign repair is completed, the re-installation of any non-Nissan parts is thefinancial responsibility of the owner and the cost to install these parts must be negotiatedbetween the dealer and the vehicle owner. The Nissan dealer may elect not to perform anyrepairs that may violate emissions or other regulations.
this is what you will recieve from the dealer telling you about it.
OWNER'S LETTER (vehicles with exhaust pipe hanger pin)Dear Nissan owner:This notice is sent to you in accordance with the requirements of the National Traffic and MotorVehicle Safety Act. Nissan has decided that a defect that relates to motor vehicle safety exists in some 2002-2003 model year Nissan Altima vehicles equipped with the 2.5 liter engine.
Reason for RecallThere is a possibility that the exhaust pipe hanger pin may catch debris from the road that could be ignited by contact with the catalytic converter and cause a fire. In addition, there is a possibility that certain engine operating conditions may cause damage to the pre-catalyst. Material from inside a damaged pre-catalyst could enter the engine and result in increased oil consumption. If the engineoil level is not checked on a periodic basis and drops below the low level, and the driver continues to operate the vehicle ignoring noticeable engine noise, engine damage may occur which could result in a fire.
What Nissan Will DoIn order to prevent these incidents from occurring, your Nissan dealer will shorten the exhaust pipe hanger pin. The dealer will also reprogram the electronic control module to prevent any future damage to the pre-catalyst. In addition, the dealer will install heat shields on certain components of the exhaust system on vehicles that do not already have them. This free service should take about three hours to complete, but your Nissan dealer may require your vehicle for a longer period of time based upon the dealer's work schedule.The pre-catalyst will be tested to ensure it is working properly and replaced if necessary. If damage is found inside the pre-catalyst, it will be necessary to replace the engine. Nissan anticipates that few engines will need to be replaced. If the engine needs to be replaced, this also will be free of charge and will take several days. In this case, a car rental allowance is available from your Nissan dealer upon request.
NOTE: If the engine or exhaust system of your vehicle has been modified with non-Nissan parts orin a way not authorized by Nissan, you may be responsible for bringing the vehicle into a condition that allows the campaign diagnostic procedures to be followed and the repairs completed. If it is not possible to properly test the pre-catalyst and install all of the campaign parts, you will have to pay the cost to return the vehicle to an appropriate condition in order for the dealer to perform the campaign repairs. You may also have to pay to add any modifications back to your vehicle.
What You Should DoContact your Nissan dealer at your earliest convenience in order to arrange an appointment to have your vehicle repaired. Until then, check engine oil regularly and fill as needed. If you notice excessive engine noise or an abnormal odor from the engine compartment, you should stopdriving and contact your Nissan dealer to arrange to have the vehicle towed to the dealer forrepair. Please bring this notice with you when you keep your service appointment. Instructionshave been sent to your Nissan dealer.
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
this recall happened a while back, but thanks for the information, it is greatly appreciated
NISTECH
this recall is dated july 29 2003.
nlzmo400r
NISTECH wrote:this recall is dated july 29 2003.
realy? cause i heard the EXACT (word for word) same recall a while back, that had to be atleats 3 or 4 months ago, i also heard a problem of the cat thats coupled to the header becoming too hot and catching fire
PalmerWMD
Car: 2004 350Z
Scott:
Thanks for the scoop!
Fred..:thumbup
nlzmo400r
fred, do u remember seeing a previous post about the same recall? either that or im having serious de ja vou, cause i couldve sworn ive seen teh exact same recall on these forums
soilwork240sx
im with nlzmo here. i saw the same thing posted here not too long ago like maybe earlier this year. your not crazy man dont worry.
NISTECH
find the link. I have been with nissan for 8 yrs. I knew approximatly 1 month prior to the recall it was coming but it was very hush hush with nissan so if it got on this site it had to of come from someone in NNA. Now there was a concern with the oil consumption problem for a good year or so before but nissan was not running a recall for that. this condition with the cat may have been related to the oil consumtion problem on some vehicles but was not discovered till about 6 months prior to its release. Research and development took place during the six months to find the cause and the last month lay out of the recall was performed. but if you can find the post you are refeering to that discusses the cat problem and the reprogramm of the ecm I will retract this statement.
Scott :D
NISTECH
retracted!!! now I need to find out where he got this info
http://www.nissaninfiniticlub....ecall
nlzmo400r
haha, ahh the madness
Return to “3rd Generation Altima Sedan (2002-2006)”
