pchast wrote:The Idling was just this morning while I plowed out the bottom of
the driveway. With all the time at the last dealer and my fiddling I got 15.6 this time... That's not a real number. I'll get a real number early next week I hope.
Well, at any rate,, liveing up North in the Cold Belt,, If I had purchased a New Truck or Car,, I wouldn't drive it home,, without haveing a Block Heater Installed.
A Block Heater heat's the Engine Coolant,, which is used to Heat the Heater Core,, which then heat's the Air to Heat the Cabin.
The Block Heater preheat's the Engine,, which make's for much easier Starting and therefore preheat's the Engine Oil as well, which help's lubricate the Engine on Startup.
I think that I read,, that All Canadian Nissan's come Standard with a Block Heater. You live close enough to Canada,, that a Block Heater Make's Good Sense. Sure it will cost a little bit for the Heater/Install,, but in the long run,, you'll get that back,, and will be attractive when time for Resale or Trade.
I guess it would also be a good idea to have the Nissan Tech to check the Hot Air coming out of the Duct's to see if it is within Spec. If not,, it might be something to do with the Thermostat,, not working correctly.
Next time, when You take your Truck in, You have to talk with the Service Writer,, but also make an appointment to talk with the "Service Manager", and tell them what is going on.
If I lived up there with all the Ice, Snow,, Wind,, and Fridgid Cold Weather,, I wouldn't be without a "Block Heater",, it just make's good sense. As somewhat of a Testimonial,, Just about all Tractor Owner's up there install or have a Block Heater Installed, so that there Engine's will Fire Up to Remove Snow.
Good Luck,
