shrapnail »
https://forums.nicoclub.com/shrapnail-u42375.html
Thu Mar 26, 2009 12:00 pm
Tac show's 0 RPM, car has trouble starting (possibly unrelated, horrible gas here, possibly related due to fuel management tie-in?); engine sounds fine while running.Car accelerates through it fine, needle will "jump up" once you hit 4k or so on a rough acceleration. Car dies @ idle (again possible fuel tie in), have to feed fuel constant @ a stop to keep from dieing. Needle will occasionally deflect to actual rpm in normal driving state, but rather infrequently.
After car has been on 3-5 minutes problem clears. If car is off 15-20 mins will still have problems @ start up.
Occasionally car will stutter while driving (jerk, like if you are in the wrong gear taking off and not enough gas). On one such occasion (it's only happened 2-3 times, though I tend not to drive off till tac corrects now) I cycled through 4th to 1st to no affect. Initially thought it was the gas (b4 the tac was getting "stuck") and filter, so I ran an additive through it to avoid purchasing a new fuel pump.
Thoughts? where's the transducer/sensor hooked up (don't have much time to research right now, maybe this weekend)? ECU issue?
Anyone have any experience with this?
