RicerX »
https://forums.nicoclub.com/ricerx-u125542.html
Fri Jan 18, 2013 6:02 am
Sounds like some sort of voltage issue to me, causing a stall.
How many miles do you have on the car? It is possible it's spark plug time. Also, a battery with exceptionally low voltage can actually cause a car to stall. I have had this happen in two vehicles. When the proper conditions are present, this is not unusual. In my case, it was the car dropping to idle and the AC system clutching on (I know it's winter, but your defroster uses the AC system, so this can happen if you are running that). I also possibly second the battery issues as I have witnessed several alternator issues with the early 4th gen 2.5 Altimas. The alternator works but sometimes doesn't generate the proper load to sustain the car, which could also trigger a stall.
Any number of things here. Good luck. My instincts lie within the above blurb though.
