2.5 and 3 inch ic piping question
projeks13
Car: 89' 240sx coupe
so i ended up with just enough piping to make one side with each size(2.5" & 3"). which side should get the 3" hot of cold? i have a medium sized rectangular shaped intercooler not too crazy big.
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
2.5 hot and 3" cold imo.
Since we are on the same subject, which size do you guys recommand on a rb20 with rb25 turbo? Im thinking 2.75 or 3" on both cold and hot. Thanks.
IronMonkey
If you have to do it, 3" on cold, and 2.5"
For a rb25 turbo, Id just keep it down to 2.5" all around. I dont see the point of going any bigger if you dont intend on bigger power in the future as it will delay your spool up.
projeks13
thanks guys your right about keeping it around 2.5~2.75ish but thats just the way a poor dude ended up
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Just some advise...
Try and stay with bends larger than 90 deg if possible if you are making a custom piping setup
As for piping size... I still question the need for 3" piping (can't believe on a car with less than say 400hp 2.5" will choke airflow... unless maybe the amount of bends merrits the larger diameter... but I'm not sure on that... just a guess). If you do use it, please gradually step up to that size, or carry 3" from the IC exit all the way to the TB so you don't get a significant, instant pressure drop in the pipe.
