evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Mar 14, 2008 5:17 pm
some 2 piece wheels are meant to be serviced, meaning you can take them apart powercoat and reassemble without issue, just be sure you do not coat the mounting surface you want a positive, even, flat contact, other 2 piece wheels are press fit or heat fit before bolting and in some cases welding, these are not servicable, check with the wheel manufacturer, if they sell new centers and shells seperately then they are servicable, if not then you'll want to not try taking them apart
