gs14racer »
https://forums.nicoclub.com/gs14racer-u58274.html
Fri Sep 26, 2008 1:06 pm
Ok a little bit of wrong info yesterday. Its only on the passenger side coil bank specificlly cylnder number 6.
Here you can see both in the pictures. It goes from the ingnitor the brides the coil and the resitor together, then the other side of the resistor goes to ground. The single clip I am holding is the resitor ground wire, you can open the ground on the resistor by uncliping this.
Ground for the resistor
index finger is the resistor
