BigTDogg (MA) wrote:The best way to mount it is to not use an FMIC in the first place.
Ace2cool wrote:LOL! I gotta agree though. My roommate used a generic steel bracket that we bought at home depot, and rigged it up using that. It's like 1/8" steel, 90* bend, and goes across the bumper support the width of the IC.
skywhine wrote:
On another note when i first intalled it i loved to get out after a hard drive and put one hand on the hot pipe and one on the cold pipe. One was deffinately Warm and the other deffinately COLD...So it doed work despite it being an ebay product. Also keep in mind im not looking to save .010's of a second on lap/drag times. Im just drifting..so eventually ill smash it anyways.
Yea i have thought about that. so i am gunna try the GSP with stock bumper, if that doesnt work well enough i will probably wind up getting SMIC's. but For now FMIC it is.skywhine wrote:If its "good enough" for the 500hp competition drift car im planning, it should be just fine on a daily. By competetion i do not mean formula d, im not trying to fan boy out here. However as others will most likely chime in with: Their is a big difference between "good enough" and actual quality. I would venture to say its better than stock (Or at least larger) but i may not be correct. Like i said, i only did it for looks. Otherwise i would have went with the z1 SMIC. The Z1's actually have an enthusiasts R&D with actual dyno runs. The GSP is just a cast aluminum copy of a GReddy or other quality end tanks on a generic bar and plkate core. It all depends on what YOU want.
The other thing to consider is if you put an FMIC under the factory bumper without hacking it up their will be virtually no airflow going to it with such a small opening in the bumper. Even my WW bumper blocks flow to the top 1/4 of the FMIC. So actually 1/2 of the top intercooler is blocked. The FMIC is essentially 2 small intercoolers stacked on top of eachother.
Lol, a little sarcastic tonight, eh? He's being completely honest though.zfan4life wrote:Thank you for your WAY TOO HELPFUL post :-)BigTDogg (MA) wrote:The best way to mount it is to not use an FMIC in the first place.
Yea i saw that, i was asking for maybe some closer of how its mounted there... i see the general area but not the actual mounting. Thankyouskywhine wrote:I posted pix
