Phax »
https://forums.nicoclub.com/phax-u2813.html
Fri Jun 20, 2003 10:09 am
Stroker kits are nice, and more displacement is always a good thing. You can realize the same performance increases for slightly less with a larger turbo, appropriate fueling, and proper engine management. If the ~350-400hp that you can make on 2 liters isn't good enough for you, then look at getting a stroker kit.
If you're like most people, it would be overkill. But sometimes, if you've got too much cash... overkill is good. :ylsuper
