2+2 dash??
DevZX
Car: 1990 300zx twin turbo
1995 miata mx-5
1990 miata mx-5
hey guys just wondering is the 2+2 dash board and the 2 seater the same? my friend said the 2+2 will fit in the 2 seater nut i didnt think so.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I believe the dash should be the same, but the center console is different. I can't be 100% positive on that though. You'd have to check part numbers, and good luck finding that info.
Ace2cool
Nevermind, they are the same. The only difference is 90-93 (no airbag) and 94+ (SRS Airbag) And dayumm are they expensive
http://www.conceptzperformance.com/cart ... 25.226.212
johnshop
Car: 1995 nissan 300zx na 2+2
holy... s***... for that money you could get a non running z with a decent interior... heck my running 2+2 is probably worth that ahahah
DevZX
1995 miata mx-5
1990 miata mx-5
Thanks man cause my dash is peeling and almost ever bracket is broken.. and i got one in perfect condition from my friend for $100 only problem is its black.... and my interior is red. I guess i have to add some more black in their to make it look better
BlackWidowZ
Car: Black 93 300zx 2+2
my 93 2+2 has a drivers side airbag. Although the airbag is on the steering wheel not the dash. 94+ have passenger side dash airbags. I don't know if there is such a dramatic change of circuitry behind the dash that would change the mounting holes of the dash....so it may not make a difference otherwise the dimensions are the same for all z32s i believe.You can probably use both on a anything up to a 93 you will just have a spot for a airbag but wont have anything under there....94+ you have to use the one with the airbag.
BlackWidowZ
DevZX wrote:Thanks man cause my dash is peeling and almost ever bracket is broken.. and i got one in perfect condition from my friend for $100 only problem is its black.... and my interior is red. I guess i have to add some more black in their to make it look better
You can try to match the color and paint it since its black.. you need special paint though. not just any type of paint will look right. Just don't put too much paint.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
I wouldn't paint the dash it will never look right and eventually start chipping. The red interior actually looks really good with black accented through it though.
Ace2cool
Z-owned wrote:I wouldn't paint the dash it will never look right and eventually start chipping. The red interior actually looks really good with black accented through it though.
:yesnod
DevZX
1995 miata mx-5
1990 miata mx-5
Yeah so black dash and i think ill do black seats also since he also. And what about those ebay trim kits that replace all the cloth in black?? Or do u think that would be overdoseing on black??
Ace2cool
That would just be a black interior. Nothing wrong with that, unless you're planning on leaving the hatch red.
