2 12" with custom box??
Leoltima
Car: 2009 Nissan Altima Coupe 2.5
Is this possible??? I already got my subs but am willing to customize a box. any suggestions???
AppleBonker
Leoltima wrote:Is this possible??? I already got my subs but am willing to customize a box. any suggestions???
It would be possible, but would likely require a good amount of work. It would be easier if you're willing to remove the spare and foam around it. Either way, you will consume a great deal of trunk space with 2 12s. Because of that, I would recommend going with a fiberglass enclosure to minimize the amount of trunk space you will use (while still providing ample volume for the subs).
Mr. Watts
You could do 2 12's sealed, but like the guy above said, you wont have much trunk left. But if you want to go ported then forget it. I could only come up with about 3 cubic feet ported, and most dual 12's need 4-5 cuft. I was heart-broken when i found out i couldn't fit my 12's in there
unique2.5
Car: 2009 Nissan Altima Coupe 2.5S
even with a standard box rectangular box you can fit them facing up but in the front part of your trunk(not under the 6x9's)
if you remove the spare then you definitely open up some room and can fit a custom box with 2 12's
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Mr. Watts wrote:You could do 2 12's sealed, but like the guy above said, you wont have much trunk left. But if you want to go ported then forget it. I could only come up with about 3 cubic feet ported, and most dual 12's need 4-5 cuft. I was heart-broken when i found out i couldn't fit my 12's in there
Wouldn't you gain the cubic ft needed if you mounted the subs facing the rear seats, essentially using the whole trunk as an enclosure? Just a thought..I don't do this for a livin..
unique2.5
yeah that would help partially but then you still have the issue of taking up a lot of trunk space(if thats an issue for you) and that hes trying to fit 2 12"s and no matter how you face them there isnt 12" between the false floor and the 6x9s meaning you would need to do some modification if you wanna do that
mikegtr06
Car: 1995 180sx
there is 12 in...... so if they are angled even slightly they will fit.
unique2.5
i mean it is possible but then you have to factor in the box so lets say the subs are 12" then with the box it would probably be close to 14" i dont wanna do the math to figure out how much they have to be angled to make it work
StrokerAce
Car: 07' Nissan Altima 2.5s
91' 240sx SR20DET
Leoltima wrote:Is this possible??? I already got my subs but am willing to customize a box. any suggestions??? <IMG NAME="icon" SRC="http://www.nicoclub.com/forums/Xsmileys/Xcool.gif" BORDER="0">
im not sure if it is the same measurements, but i have an 07 sedan and fit 2 12's in a ported box into my trunk. not much trunk space left, but i did it.
unique2.5
sedan is a different story my friend
