2,000 rpm max
NCsilvia88
Car: 1995 nissan 240 sx sr2odet
ive been working on my 240 for a while now and finally manged to get it started after replacing the fuel pump with a walbro 255 and a new fuel filter. i re did the timing, and checked all the connections but my sr wont rev past 2,000 rpms i have checked all the spark plugs and they all have spark. ive checked the vacuum lines and there on tight and i think there in the correct place. does any one have any ideas of what could be wrong or a picture of there vacuum lines thanks
BCNR13-specD
Car: 1985 mercedes 380se
the only thing i can think of is the fuel is not getting to the engine somehow. I would check the filter again cause even though its new you might have picked something up out of the tank and cloged it. also, kinked lines or fuel pressure regulator bad or set wrong letting too much fuel recirculate back to the tank causing enough fuel pressure for idle- 2000 but not enough fuel for anything above that. hope this helps. oh, and check the tps setting/adjustment.
NCsilvia88
thanks ill will try that out i didn't even think of that as being a possibility
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
A bad MAF will cause the engine to run in "fail safe" which will limit the RPM; check the MAF connections for tightness and for any oxidation on the pins.
EnjoiNismo
Car: 93 240sx
I had the same issue, turned out to be one of my couplers on my intercooler broke.
Check that.
NCsilvia88
So I pulled out my maf sensor and it was bad I havnt installed it yet but I am guessing that's the issue I make sure my piping is tight too thanks for all. The help
